05 Clutch has no pressure when put petal to floor
Old Nov 25, 2023 | 04:39 PM
gbr1955's Avatar
Default 05 Clutch has no pressure when put petal to floor
Petal fur clutch has no pressure
Old Jan 2, 2024 | 02:37 PM
RichB's Avatar
Check the fluid level at the master cylinder. If it is empty, check for fluid at the push rod between the clutch pedal and the master cylinder. If there is fluid there, replace the master cylinder. If there is no fluid there, the slave cylinder is probably bad. If the fluid reservoir is full, the master cylinder is probably bad. There is also the possibility that the linkage between the pedal and the master cylinder or between the slave cylinder is broken or otherwise disconnected.
radol
Apr 26, 2016 02:33 AM
bigdaveh
Jun 16, 2014 12:47 PM
harrysaimbhi
12
Mar 19, 2014 09:26 AM
mr wolf
Jul 9, 2011 01:37 PM
harrysaimbhi
23
May 6, 2010 02:42 AM
