2004 GT turbo computer issue
Old Apr 7, 2022 | 06:38 PM
Mopedboy's Avatar
Default 2004 GT turbo computer issue
I’m experiencing ECM issues. It doesn’t command the heater circuits for the oxygen sensors, vehicle running super rich, fouling plugs and extremely poor gas mileage. This is the second “refurbished” computer that I’m putting in from a company in Florida. Anyone else having these ECM issues? Does anyone have a source for a working ECM new or used
Old Apr 7, 2022 | 06:48 PM
ggoose's Avatar
Browse over to 'allpar.com'. There is a contributor 'myckee' who specializes in PT ecm's. Has a very good reputation and backs his works.
Old Apr 7, 2022 | 08:33 PM
so what are the codes in the computer? the heater circuits are designed to help it get up to operating temp thats about it they will stull run with out that feature. and certainly not foul spark plugs. Have you checked to see if they are infact getting voltage to the heater grids on the wires?
Old Apr 8, 2022 | 12:20 AM
Mopedboy's Avatar
Default Current codes are P0031&P0037
Current codes P0031&P0037, I don’t think there’s issues with wires bc tech able to activate the heaters with his scan tool
Old Apr 8, 2022 | 09:32 AM
ggoose's Avatar
The scan tool uses the ecm to activate the heaters. Have the O2 sensors been replaced? Need to replace with OEM/NGK or Denso only. No Bosch as they do not play well with chryslers.
Old Apr 8, 2022 | 06:35 PM
yeah likely bosh o2 sensor installed because the likely hood of having 2 separate o2 heater circuits be bad with the same code at the same time is like 1million to one shot.
JJC65
Apr 17, 2020 06:50 PM
Mguertin29
Jan 4, 2020 09:45 PM
MrNoizyToyz
Feb 25, 2012 08:43 AM
firsttime
Other
Dec 26, 2011 11:05 PM
jackson521
Jan 17, 2010 09:41 PM
