2004 Low Idle + oil light issue
Old Jul 6, 2016 | 12:52 AM
SpudlerT+CTouring's Avatar
Default 2004 Low Idle + oil light issue
First I noticed Idle seems low when no accessories are on and even worse when A/C is turned on, Is there a way to adjust this?
I get no codes plus no chk engine light.
looks to be idling about 700 in park (will check with my Autel 539 B scanner to get exact Idle RPM
Also somewhere there is an issue with the Oil light as it comes on internittently and I can see the engine has oil pressure as I can see it running off of top of rockers quite well when looking in through the oil cap.
is there a specific place I shoudl look for a short or do the oil sending units go bad on these?
Old Jul 6, 2016 | 06:30 PM
Idle speed is controlled by the engine computer. There's no adjustment.
Replace the oil pressure switch. You'll probably find it's leaking, but, yes, it's a known problem.
oldcars
Oct 23, 2015 09:53 PM
Dhatz
Sep 11, 2015 01:11 PM
qbasicer
Sep 25, 2012 02:58 PM
OGHBEICA8
Jun 20, 2012 10:44 PM
ijiuini
Dec 5, 2008 03:18 AM
