2006 PT overheating
Old Apr 8, 2024 | 04:47 PM
PT partner's Avatar
Default 2006 PT overheating
Last June 2023 I had to replaced cracked radiator replace hoses and rusted pipes. Started over heating again 7 Mos later. Replaced water pump & thermostat. Still overheating. Any sugestions?
Old Apr 8, 2024 | 08:49 PM
when does it over heat sitting still in traffic or when driving 50+
Old Apr 9, 2024 | 11:23 AM
PT partner's Avatar
it overheats while driving 35 to 40 mph cools off driving over 55. When I shut ot off it bubbles over. The little tank is always full to the hot level
Old Apr 9, 2024 | 04:31 PM
sota's Avatar
Bubbles are either boiling fluid or a blown head gasket.
did you replace the "radiator" cap on the thermostat housing? if it's failed it could be letting pressure out and allowing the fluid to boil.
have you considered taking it to a shop and having them do a combustion gas test?
Old Apr 9, 2024 | 07:17 PM
PT partner's Avatar
yes, just had the shop put a new thermostat. I live 8 miles from work hwy all the way 65mph. Drove to work We'd, thrs Fri. Sat had to go to town 10 miles @ 65 mph until I hit traffic. Had to wait thru 2 red lights car over heated 3/4 to Hot. I parked when it cooled I put 1 gallon of water in it and went home. Taking it to the shop tomorrow. I'll ask about what you said. Thank You very much
Old Apr 11, 2024 | 10:17 PM
Does the fan come on ? Im betting its not because the faster you drive the cooler it gets and shop and go traffic it will over heat because the fan is not coming on. put on the ac when the car is still still the fan should come on in 10 15 seconds
Old Apr 23, 2024 | 08:33 AM
PT partner's Avatar
The shop found a very small leak in head gasket. Am resurfacing the head. The job is pricey, but I can't afford a new car. Thank you for all your help.
Old Apr 25, 2024 | 09:57 PM
I still think you have a fan issue because if the head was warped it would be more of an issue when your driving 65plus not sitting in traffic.
Stats
Sep 21, 2023 05:44 AM
Wrinkle
Jul 29, 2023 11:51 AM
mkovacs
Jul 15, 2022 03:11 PM
Trotts19
Apr 9, 2009 11:40 PM
ptqueen79
Dec 30, 2008 02:56 PM
