5 speed shifter has no control
Old Feb 12, 2018 | 06:02 PM
Bob Haggard's Avatar
Default 5 speed shifter has no control
We have a 2006 GT turbo with 5 speed manual. The shifter has no control like something broken or disconnected. What do I need to fix or replace?
Old Feb 20, 2018 | 11:14 AM
TurboRev's Avatar
Look in your engine bay near the transmission itself and verify the cable is still properly connected to it. I've had a clutch cable slip off of its shifter fork on the transmission which gave similar symptoms. If you can't feel it go into any gears, possibly your gear shifter cable gave up or something similar? http://www.moparpartsgiant.com/parts...-controls.html
Old May 12, 2018 | 08:27 PM
Golferdon's Avatar
Hello Bob, New member to forum but have a 2001 PT 5 speed. Your problem could be the bushings that control the shift cable under the center console. If you're handy, it's not a major job, pull the seats, center console and replace the OEM bushings. I replaced them at about 50K miles with Bugger Racing Bushings. As you posted in Feb I suspect this is old news but... just in case.
Golferdon
Old May 12, 2018 | 08:35 PM
BiliTheAxe's Avatar
If you go under the car, make VERY sure that you use jack stands, and block the wheels from turning along with making sure that the emergency brake is on.
If you move the wrong thing on the transmission, the car could start to roll if you do not take precautions.
johnpvb
Jun 27, 2016 02:44 PM
bdj5773
Aug 20, 2012 11:38 AM
TravisAz
Aug 26, 2009 01:45 PM
tma20sc
Jun 5, 2009 08:56 AM
69Datsun240Z
Aug 5, 2007 10:09 AM
