Check Engine P 304
Could be a bad fuel injector on #4, or a problem with the valvetrain for same cylinder. Do a compression test, if #4 is lower than the other 3 cylinders, you are looking at some head work to be done. If OK, and you are getting rich running and gas dilution in the oil, or no spray at all,an injector problem. Wet or dark porcelain tip at the electrode, or totally white and looking like brand new would denote where the trouble lies.
Also did you stay with the factory recommended plus?
Chrysler Forum Editor
Oct 15, 2012 04:58 PM
RobinVA
Jan 5, 2010 10:18 PM
ceyhun_82
Aug 28, 2009 09:09 AM
sebringphanatic
Jul 25, 2009 12:03 AM
