Code P1163
Old Aug 26, 2024 | 01:07 PM
IkesterM's Avatar
Default Code P1163
I have been working for a long time to clear a EGR code on my 2002 PT Cruiser with 174K miles. Finally found a bad seal in the tube from the exhaust manifold to the intake manifold. Now I get a code P1163. Is this something to do with the catalytic converter or? How to fix it? Thanks
Old Aug 26, 2024 | 07:37 PM
Recheck your codes p1163 is not a valid code for this year
Old Sep 5, 2024 | 07:02 PM
IkesterM's Avatar
Default Code P1163
The work I did cured the EGR code, but immediately at start the code P1163 comes in. I have cleared it several times and it comes back the same.
Old Sep 6, 2024 | 08:26 AM
ggoose's Avatar
Suggest using a different OBD reader or visiting an auto parts strore to have the codes read and verified. Have the stored codes pulled as there may be no longer active that may give additional information.
Old Sep 8, 2024 | 03:43 PM
IkesterM's Avatar
You are right! Took it to O'Reillys and the code was P-1169-air intake temperature sensor. Replaced the sensor and no mor check engine light! Thanks for the help!
Old Sep 11, 2024 | 09:04 AM
ggoose's Avatar
Appreciate the follow-up and resolution. Ups the usefulness of these sites.
Ramtruck
May 13, 2024 10:21 PM
Crzmn1
9
Sep 16, 2022 08:33 PM
Extortion00
Feb 21, 2016 09:32 PM
marauder3971
Nov 2, 2012 10:04 PM
IGUANA
Aug 28, 2010 08:32 PM
