Just can't shake this code
Old Feb 17, 2016 | 07:56 PM
Extortion00's Avatar
Default Just can't shake this code
Code P0401 EGR insufficient flow detected
I Replaced the EGR and i am still getting this code after about 10 miles of driving after resetting the code... Any ideas where to go from here
Old Feb 17, 2016 | 07:57 PM
2004 Pacifica 3.5L
Old Feb 19, 2016 | 12:08 AM
aftermarket egr valve?
Old Feb 19, 2016 | 02:12 AM
Possibly I just went to my local parts store and asked what I needed
Old Feb 19, 2016 | 09:16 PM
yep thats what it would be probably need to get a dealer one.
Old Feb 21, 2016 | 01:14 PM
busboy4's Avatar
I'm not arguing with Chrysler Tech, but for what its worth I did change mine out with an EGR from O'reilly for a different issue -sluggish acceleration and idle maneuvering stalling- and have had no codes or problems. I have, on Honda's and a few Fords cleaned out "EGR ports" in the intake. On both vehicle makes several were clogged with carbon buildup. I'm not sure if the Pac engines have similar issues. Kevin?
Also, RockAuto sells an OEM EGR.
Old Feb 21, 2016 | 09:32 PM
the P0401 EGR insufficient flow detected which teh computer controls the solenoid plunger inside the egr to add or take away the amount of exhaust that the system wants. so if the egr was replaced already and your getting this code either the port is flawed or its not fact enough for the computer to allow it to work. been there done that with the pacs
RCracer51
Feb 26, 2012 01:40 PM
jt_624
Dec 4, 2011 05:32 PM
robbg77
May 26, 2011 07:43 PM
New yorker 95
Jun 26, 2008 02:22 PM
97K15004WD
Aug 26, 2007 07:35 PM
