Crank no start
Old May 18, 2022 | 08:48 PM
Chryslerboi's Avatar
Default Crank no start
2001 PT cruiser 2.4l non turbo has spark,fuel,timing, and compression I've also replaced the crank sensor but it won't start it cranks and if I crank it and have it at full throttle it tries but never start. Please help she's my only daily and can't afford a new one right now
Old May 18, 2022 | 09:03 PM
spray brake cleaner or starting fluid into the throttle body does it attempt to start ?
Old May 18, 2022 | 11:37 PM
no it does not
Old May 19, 2022 | 10:31 PM
get a spark tester from about any store put i inline to the coil wires see if it flashes when starting.
Old May 20, 2022 | 12:09 AM
​​​​​​All spark plugs are getting spark and the sparkplugs coilpack and wires are brand new
Old May 20, 2022 | 09:35 AM
codes in the computer?
Old May 20, 2022 | 01:20 PM
No there are no codes either I'm really stumped here
Old May 20, 2022 | 06:27 PM
only need 3 things spark fuel and air so haft to be missing one of them noid light on the injectors it is shooting fuel?
Old May 21, 2022 | 11:40 AM
ggoose's Avatar
How many miles? Has the timing belt ever been changed?
You noted compression, how was this determined? Were readings taken on each of the cylinders and what were the numbers?
Old May 21, 2022 | 01:45 PM
It has about 180,000 miles And I used a compression gauge where I took the spark plugs out and attached it to there and I don't remember the exact amount but I remember that it was a correctly running amount And I ripped apart the side of the engine to see if the belt slipped or was torn. It is not. The engine is in timing. It's all correct and the belt is fine The engine is in timing. It's all correct and the belt is fine
