Crank no start
Old Nov 1, 2022 | 10:23 AM
moparrh's Avatar
Did you come up with a solution? I have a 2003 with standard 2.4 that does the same thing.
Old Nov 1, 2022 | 02:23 PM
moparrh's Avatar
Originally Posted by Chryslerboi
It has about 180,000 miles And I used a compression gauge where I took the spark plugs out and attached it to there and I don't remember the exact amount but I remember that it was a correctly running amount And I ripped apart the side of the engine to see if the belt slipped or was torn. It is not. The engine is in timing. It's all correct and the belt is fine The engine is in timing. It's all correct and the belt is fine
I have a 2003 with the same symptoms. Did you find a solution?
Will.Ambo
Jun 20, 2023 01:26 PM
BGHobbs
Jul 19, 2021 12:14 PM
Givenusome
Apr 21, 2021 12:57 PM
2005Cruiser
Aug 20, 2018 08:46 PM
racerfan
Sep 21, 2008 11:55 PM
