No Start
Old Mar 26, 2024 | 07:42 AM
POP TOP's Avatar
Angry No Start
No crank, found FP/ASD fuse blown, replaced . It now turns over , tries to start but won't. All fuses and relays good. No codes, Timing belt ok and in time, have spark and fuel. HELP!
Old Mar 26, 2024 | 09:03 AM
ggoose's Avatar
How were spark and fuel verified. Please explain 'tries to start' in more detail. Does it fire, stumble, and stall or not fire at all?
Old Mar 26, 2024 | 05:58 PM
POP TOP's Avatar
fires but doesn't catch, seems to me it's out of timing!
Checked fire at all plugs, spark.
Disconnected fuel line at fuel rail, had friend turn on the ignition and gas pored out of the line into a coffee can. pulled #1 plug and it is wet! Pulled all plugs and installed new ones. Plug wires are about a year old.
Old Mar 26, 2024 | 09:21 PM
what year PT turbo or non?
Old Mar 27, 2024 | 11:21 AM
ggoose's Avatar
Good fuel flow does not indicate adequate fuel pressure - should be around 48psi +- 5psi. Low fuel pressure can dribble enough fuel to fire but not enough to run. Low fuel pressure will not atomized the fuel sufficiently to run which may result in a wet plug. Given that the FP/ASD fuse was blown may indicate the fuel pump is having issues.
Were Champion/NGK copper plugs used? These 4-bangers seem to like copper plugs.
Old Mar 27, 2024 | 02:04 PM
POP TOP's Avatar
It's a 2005 Turbo, Just checked fuel pressure and it's 55psi
Arodws6
Mar 28, 2024 08:35 AM
Givenusome
Apr 21, 2021 12:57 PM
cliff1968
Dec 10, 2017 02:01 PM
Jeepguy91
Jan 5, 2014 07:09 PM
PSD4life
Sep 27, 2011 05:22 AM
