Whole engine spins but won’t crank
Old Apr 18, 2021 | 10:07 AM
Givenusome's Avatar
Default Whole engine spins but won’t crank
I have a 2001 PT Cruiser. Is giving me issues. The car just turned over 200k miles but runs strong. Then it died. Whole engine spins and sounds like a drill. It sounds like it’s not cranking though. I can see the crank pulley spinning as well as the cams. I just replaced the timing belt. I did check the timing marks on the cams as well as the crank before I put car back together. I also replaced the cam shaft sensor and the crank shaft sensor. I checked for fuel and spark, getting both. I’m not sure where else to start looking. Nor am I sure why it won’t attempt to start.
Old Apr 19, 2021 | 07:10 PM
If you have fuel and spark, it should start unless the timing is way off. Check the compression to see if there is any. If not, go back and look at the valve timing again. Make sure you're not 180º off.
Old Apr 21, 2021 | 12:57 PM
ggoose's Avatar
Did the timing belt break the first time it died and is why the timing belt was replaced? What you describe with the engine spinning like a drill indicates there is no compression.
The next order of business is to do a compression check. Though the engine is non-interference, meaning the pistons won't hit the valves if the timing belt breaks, it is possible the cams got out of phase when the belt broke and the intake and exhaust valves collided and are bent.
Nealsllvn
Dec 24, 2015 08:28 AM
Turboblackbird
Aug 29, 2015 07:49 PM
Skippiemac
Feb 13, 2009 07:59 PM
Mizhan6
Oct 21, 2008 04:37 PM
racerfan
Sep 21, 2008 11:55 PM
