2007 pacifica cranks but won't start
Old Dec 7, 2017 | 11:51 AM
cliff1968's Avatar
Default 2007 pacifica cranks but won't start
i checked all fuse and relays gave it a shot of either in throttle body it wants to start have fuel to fuel rail the injectors are not feeding the cylinders.replaced crank and cam sensors. parked car would not start next morning any help is greatly appreiciated
Old Dec 7, 2017 | 02:30 PM
REBEL59's Avatar
Can you clarify..wants to start..with ether? Does it run on the amount sprayed or VERY roughly. How many miles on the vehicle and has the timing belt ever been replaced?
If the check engine light has been illuminated before this suddenly happened there will be diagnostic fault codes stored in the ECM and should be retrieved to help guide you in nailing down the fault. It works a lot better than throwing in parts that may not be the cause of the problem.
Old Dec 7, 2017 | 04:47 PM
cliff1968's Avatar
does start with either no codes ran great shut it off and would not start the next morning i'm thinking fuse box or ecm
Old Dec 9, 2017 | 11:19 AM
REBEL59's Avatar
Well if it runs on starter fluid..You have a fuel problem..POSSIBLE fuel pump issue. When you turn key to run position(not crank)do you hear the fuel pump whir for a few seconds?
Old Dec 10, 2017 | 02:01 PM
cliff1968's Avatar
problem found had a broken wire (red/black) connector behind bumper cover next to the ecm repaired wire runs great thanks for all the help
Rupucis
Feb 6, 2020 04:15 AM
sbd9902
Feb 5, 2020 04:05 AM
Ebk4locster
Aug 7, 2015 08:07 PM
DanNotTheMan
Sep 17, 2012 01:36 PM
Greg
Jul 30, 2009 09:34 AM
