Oil Pressure Light Comes On
Old Jan 20, 2009 | 05:34 PM
clueless's Avatar
Default Oil Pressure Light Comes On
My car has been sitting for about two weeks. Today I started it (easily) and drove it at speeds less than 50mph for about fifteen miles. At about the ten mile point, the oil pressure light began to come on and go off intermittantly. There is plenty of oil and it was changed less than 3K miles ago. Temps here are about 40 degrees. Help!
Old Jan 20, 2009 | 06:03 PM
Default RE: Oil Pressure Light Comes On
It's either a problem with the sending unit (cheap) or a more serious problem (expensive). Get it checked right away. If you feel up to it, replace the sending unit and see if that cures the problem. It's on the front side of the engine toward the passenger side of the car, accessible from underneath.
If that doesn't take care of the problem, it may be a result of a worn oil pump or badly worn engine bearings. Those are major problems.
Briarly
Dec 29, 2017 10:17 AM
Vol 04 T&C
Oct 24, 2013 09:33 PM
vladio
Apr 5, 2012 09:35 AM
jalo215
Jan 30, 2012 07:01 PM
GOVOLS123
Aug 15, 2011 01:16 PM
