oil sending unit
Old May 31, 2020 | 12:36 PM
Mark Funk's Avatar
Default oil sending unit
will a bad oil sending unit prevent car from starting?
Old May 31, 2020 | 06:34 PM
No. If it won't start, you've got other problems. Get the codes read, if any, and come back with more information such as, year make and model, engine size and mileage, and what lead to the problem and what, if anything, have you done to try to remedy it.
Old May 31, 2020 | 07:46 PM
Mark Funk's Avatar
04 pt cruiser 2.4 turbo 135,000 miles, driving to work the turbo went bad, pouring smoke out the exhaust, my oil ended up in my turbo to charge air cooler intake duct, managed to drive it home and cut it off, it would still start but made terrible noise as expected, car sat 6 months replaced exhaust manifold and turbo put in new battery, tried to start it turned the key and motor wouldn't turn over, dash lights all on but nothing when turn key, thanks for any suggestions
Old May 31, 2020 | 09:25 PM
Is the engine seized?
Old Jun 1, 2020 | 06:15 AM
Mark Funk's Avatar
no ran when stopped acts like there is no power to starter it wont engage
Old Jun 1, 2020 | 09:01 AM
If it ran until it stopped it could be seized. Put a wrench on the damper pulley bolt and see if the crankshaft will turn, even slightly. If the crank can be turned, then check the starter motor and see why it's not turning.
Old Jun 3, 2020 | 08:10 PM
Mark Funk's Avatar
yeah, a mouse had chewed through the wires, I fixed that now it is running again, thanks for your help
Nathan Laser Williams
Oct 8, 2019 03:17 AM
numbermonkey
Jun 5, 2017 05:34 PM
cirrus98
Apr 1, 2013 11:04 AM
Darren
Nov 25, 2009 06:44 PM
24todd
Feb 24, 2008 12:42 PM
