Out of patience!!!!
Old Nov 28, 2020 | 04:53 PM
Jerm43209's Avatar
Default Out of patience!!!!
Ok, so my fan wasn't kicking on, I checked it out, and one side didn't work, So I installed a new one (also new relays). Still didn't work, and I had a slight rough idle, so I thought ok, for $20, I'll go ahead and replace the temp sensor too... The rough idle went away, so I thought ok, it should kick on now.... But it didn't 🤬..... So I checked voltage at the relays. 12 volts on the red and blue wires, but only half a volt on the gray wire when the vehicle is warmed up. I would think thats enough to signal the relay to click, but im not sure. I've switched relays and checked everything... I've even added a ground wire to make sure its not a crap ground, and that didn't help either..... Im so confused about this .... My AC doesn't work, and the fan doesn't run with AC turned on (that doesn't bother me, thats something wrong with the AC), but it should still run on the cooling side, instead of just overheating in traffic..... Any ideas on what is wrong, or new things to check?????!!!! Any help is greatly appreciated
Old Nov 28, 2020 | 06:22 PM
year of the pt cruister you have? and you installed a new fan assembly? bit confused by this statement "I checked it out, and one side didn't work,"
there is only one fan its not a dual fan system.
Old Nov 28, 2020 | 11:19 PM
Jerm43209's Avatar
Sorry about the confusion....One side didnt work, as in, either the high side or low side didn't work.... Fan plug has 1 ground in the middle, and a red power feed on either side of that (3 wires).... Car is an '06 non turbo... New fan assembly/relays, new coolant temp sensor, 50 amp fuse is good, Im getting 12 volts to relay on red and blue wire, .5 volts to gray wire (signal from ecm) ... Is it not enough to click the relay? I dont know how much its supposed to get from the computer as a signal... Ive even added a ground, because I've had issues with dodge grounds being an issue for me in the past.
Old Nov 29, 2020 | 04:32 PM
sure its an o6 because the 06 has 4 wires going to the fan module and the power for the fan speed is from the tipm. no relay on the fan assembly.
Old Nov 29, 2020 | 04:51 PM
Jerm43209's Avatar
June 06 is date of assembly on door sticker..... 4 wire plug from car to fan assembly (goes to 2 relays on upper right side), 3 wire plug from relays to actual fan
Old Nov 29, 2020 | 05:05 PM
open the fuse box are there 2 fan relays or none at all?
Old Nov 29, 2020 | 05:11 PM
Jerm43209's Avatar
My fan looks like this...
Old Nov 29, 2020 | 05:13 PM
Jerm43209's Avatar
Only a fuse in the fuse box
Old Nov 29, 2020 | 05:16 PM
ok yeah the TIPM setup so what you have is a bad TIMP fuse box basically.
Old Nov 29, 2020 | 05:20 PM
Jerm43209's Avatar
So the fuse box is bad, even if I'm getting power to the fan assembly? Where does the signal wire come from? ..... Would changing the fuse box fix it?
