Out of patience!!!!
Old Nov 29, 2020 | 05:31 PM
your getting main 12v power to turn the fans on. the other 2 wires are the control wires from the fuse box to turn the relays on one high speed relay one low speed relay.
The tipm is a computer in itself no fuses no relays only solid state drivers for alot of things. like lights and so on.
Old Nov 30, 2020 | 10:32 AM
Jerm43209's Avatar
I see what you're saying now. I wasnt used to this type of setup, I'm going to order another Tipm. Can I get a used one from a junk yard, or will it not function with my car? Its a base model pt, nothing special about it
Old Nov 30, 2020 | 05:44 PM
used one should be fine. There are people out there that rebuild them as well
Old Nov 30, 2020 | 07:06 PM
Jerm43209's Avatar
Thanks for the info, its been very helpful. I've worked on cars for years, and i havent encountered the tipm setup, until now
Old Dec 19, 2020 | 01:36 PM
  #15
Jerm43209's Avatar
Any other ideas for what to check, if changing the tipm didn't work? I thought it might be a faulty module, since I bought a used one, but I got it switched with another one under warranty.... Still the same problem 2 modules later, the only thing that doesn't work is the fan
Old Dec 20, 2020 | 09:11 AM
  #16
Jerm43209's Avatar
My code reader is saying it is "fan 2 control circuit", if that helps at all
Old Dec 20, 2020 | 12:43 PM
  #17
ggoose's Avatar
What is the actual code? There are various trouble-shooting guide.s depending on the code.
Old Dec 20, 2020 | 01:49 PM
  #18
Jerm43209's Avatar
PO481 - Fan 2 Control Circuit
Old Dec 20, 2020 | 04:10 PM
  #19
Jerm43209's Avatar
I think this code pertains to my a/c not working, but still doesn't explain why my fan doesn't work at all. I would like to be able to fix it all, but I would settle for the car not overheating in traffic
Andrew Smithson
Jun 15, 2020 08:37 PM
ChryslerHassles
Jun 18, 2019 12:29 PM
Killavolt
Aug 23, 2018 11:25 AM
Cheg
Jun 18, 2013 11:51 PM
xzsbkn
Jun 18, 2013 11:07 AM
