Chrysler PT CruiserOffering a sedan and 2 door convertible, both of which offer a naturally aspirated or turbocharged engine, this car has something to offer everyone
I know I may get a lot of flack for this, but I am considering doing a build on my cruiser. It would include a 4-6 inch lift.
I have had absolutely zero luck finding any such kit. Do any of you guys know of any company that does them?
(I’ve put an example below of a 4 inch lift on one)
rear 3 inch is easy, i made a spacer ad reinstalled the spring,
the sway bar links are a bit at the outer limits, but doable
the fronts you can use a 40 mm top puck that yeilds about 2 inches,,
and or a bottom bolt hole extension on the strut, disconect sway bar and you can install that easier ,, you can find them on ebay from tema4x4 russion federation, or https://www.universalcarlifts.com/ you can get rear spacers and inexpensive strutrs with the bottom brakets already welded on form, universal lifts i think in ga usa,, its a donk lift company
you could also do an airlift from air bagit they can move the strut mount to acomadate a lit https://www.airbagit.com/Air-Suspens...x-f-chr-40.htm
