Pt cruiser limited 2007 2.4
Old Aug 29, 2025 | 12:44 PM
ldoni123's Avatar
Default Pt cruiser limited 2007 2.4
Hi
I got a problem with charging that I can't fix.
The battery light on the dash are on, the charging is not good. Between 10.8 to 14.1.
I already changed 2 alternators and chabge the battery. I tried everything i checked the cables, there not fuse for the alternator there a tpim.
someone got idea ?
Old Aug 30, 2025 | 10:02 AM
ggoose's Avatar
Suggest inspecting and cleaning the 2 ground points on the driver side strut tower. They should be disassembled and cleaned. These ground points are known to corrode without an outward visible indication.
Another possibility is a failing PCM. Unfortunately the heat buildup in the engine compartment and the PCM location can cause the PCM to 'cook' and slowly fail. Note the charging voltage is regulated by the PCM. Replacing the PCM should be the last resort though.
Bigbaby968
Dec 7, 2024 09:01 PM
Bigbaby968
Dec 7, 2024 05:56 PM
Blasirl
May 14, 2021 01:19 PM
Joe Pontbriand
Jul 9, 2017 07:06 PM
paulstevens
Aug 26, 2016 11:53 AM
