PT Cruiser Steering rack sensor issue
Old May 29, 2007 | 02:49 PM
lee.millward's Avatar
Default PT Cruiser Steering rack sensor issue
Hi,
I bought a PT cruiser recently, and on the drive home the engine management light came on. After checking the code it ended up being the streeing rack oil sensor. I later found that the car did not have a sensor fit to the rack. Infact where the sensor should be, it was a blind hole !! I have no idea whats going on, as the rack looks original.Also the engine light will go off after approx 50 miles, then come on for 50etc etc.
Apparently this sensor is to raise the engine revs when the steering is turned on tickover. The car is fine without this sensor.... so does anyone know if there is a way this error check can be disabled to stop the light from coming on ?? Any help would be appreciated .
regards
Lee
Old May 29, 2007 | 04:15 PM
Default RE: PT Cruiser Steering rack sensor issue
what year pt engine size or last 8 of your vin humm how many miles on it?
Old May 30, 2007 | 01:23 PM
It's an 03 on a 02 plate, Engine size 1996cc
Regards
Lee
Old May 30, 2007 | 01:24 PM
It has just under 6k on the clock by the way
Regards again
Lee
Old May 30, 2007 | 01:30 PM
REMOVAL NOTE: Before proceeding, (Refer to 19 - STEERING - WARNING). [ol][*]Disconnect negative battery cable from the negative post of the battery. Be sure cable is isolated from negative post on battery.[*]Raise the vehicle. (Refer to LUBRICATION & MAINTENANCE/HOISTING - STANDARD PROCEDURE).[*]Locate the power steering fluid pressure switch on the back side of the power steering gear (Switch Location).[*]Remove the vehicle wiring harness connector from the power steering fluid pressure switch. NOTE: When removing and installing the power steering pressure switch, use a 7/8 inch deep well socket. The deep well socket will prevent damage to the plastic electrical connector area of the power steering fluid pressure switch.[*]Unscrew and remove the power steering fluid pressure switch from the power steering gear.[/ol]
[IMG]local://upfiles/1033/E93D90443F9A4796980C85A3DBC74F60.gif[/IMG]
Old May 30, 2007 | 01:37 PM
I don't think you have read my mail properly. I don't want to know how to fit a sensor.... I CAN'T fit a sensor, the hole is blind !!( no hole to the oil). Also someone has obviously damaged the thread as the hole is now WAY to big for the sensor to fit. This is why I'm wondering if you can disable the check. I know it's probably asking a lot...
Cheers anyway
Lee
Old May 30, 2007 | 03:18 PM
no u cant unless u know the program software for a chrysler computer. or if u can figure out how the sensor reads either just a on of switch or a restance switch u can rig something up to dupuclate it.
Victor L
Oct 19, 2014 06:24 AM
ettienne
Dec 14, 2010 07:33 AM
davet
Apr 1, 2010 11:44 PM
tk1780
9
Oct 30, 2007 10:39 AM
rickey1172
Oct 18, 2006 03:03 AM
