Timing
Old May 15, 2022 | 09:09 PM
IkesterM's Avatar
Default Timing
I just replaced the timing belt (more to it than that, but,). I rotated the crank four turns. I put a straight edge in line with the timing marks on the outside of the cam gears through the center of the cam gear bolts. It looks like one cam is off by a tooth. Can I change the timing by a tooth or so without having to remove the belt using the tensioner? Getting the belt on was a giant hassle I don't want to repeat. Is it safe or recommended to start the engine for a few seconds before putting all the mounts, etc back on? Thanks!
Old May 18, 2022 | 09:02 PM
belt needs to come off to move a tooth
Timothy Wayne
Apr 22, 2020 02:28 PM
Blainethemono
Sep 1, 2015 08:30 PM
gbeach
Feb 17, 2015 06:07 PM
Marky48170
May 13, 2013 08:14 PM
neveranotherchrysler
Apr 5, 2012 09:49 PM
