****CAN SOMEONE HELP TELL THE TRUTH*****REAR STUDS SNAPPED !!!!!
Old Jun 21, 2008 | 11:43 AM
NisCAPE's Avatar
Default ****CAN SOMEONE HELP TELL THE TRUTH*****REAR STUDS SNAPPED !!!!!
I have a Chrysler Voyager 3.3LE V6. On my way home last night three of the studs on the wheel snapped !!!!
I have been told they can be replaced but the whole hub needs to be removed is this true......some responses i have had tell me i dont need to take the wheels hub off, which would save me an arm and an leg !!!
Can a real expert, as i know you guys are (i alsways turn here for guidance) tell me the real score with me replacing the studs.
Much appreciated, I dont want to pay £200 plus which is what i have been quoted for this 2 hrs Job?
NisCAPE[]
Old Jun 21, 2008 | 02:14 PM
Daryl Baines's Avatar
Default RE: ****CAN SOMEONE HELP TELL THE TRUTH*****REAR STUDS SNAPPED !!!!!
ORIGINAL: NisCAPE
NisCAPE[]
I had this happen to me when I had new tires installed only when I tried to remove the lug nuts to install new brake pads
when I tried to remove the lug nuts 2 studs snapped this was on the front so I was able to get new studs in. When I have anyone remove the lug nuts I have them only tighten 90 PSI I carry my torque wrench with me and re-torque them to 100 PSI in front of the service dept. That really torques them but it works. I assume this is in the front and not the rear?
Daryl
Old Jun 21, 2008 | 08:25 PM
NisCAPE's Avatar
thanks daryl !!!!
Can anyone confirm the same for the rear, simple drill out the old nuts and in with the new ???
Old Jun 22, 2008 | 04:24 AM
Merlin's Avatar
Hi
Fronts as posted can be done rear no sorry need to remover the rub.
josh24200
Feb 24, 2021 08:17 AM
ScAndal
Oct 25, 2010 07:52 AM
snailtek
Oct 24, 2007 09:36 PM
01sebringphanatic
Mar 21, 2007 05:34 PM
Mar 11, 2006 12:12 AM
