'01 T&C Speedo Needle "Flip" Fix Needed
INSTRUMENT CLUSTER SELF- DIAGNOSTICS
Initiate instrument cluster self-diagnostic by depressing the odometer/trip reset button while turning the ignition key to the OFF and then the RUN position. This will cycle an electronic display segment check and illumination in sequence of all CCD bus activated cluster warning indicators. There are four Check (CHEC) functions:
1.CHEC 1, checks the gauges.
2.CHEC 2, checks the warning lamps.
3.CHEC 3, checks the odometer/trip meter.
4.CHEC 4, Transmission Range Indicator for the automatic transmission or the autostick transmission.
If the diagnostic procedure determines that a replacement of an instrument cluster component is required, refer to the proper component removal procedure.
stewartsoftware
May 14, 2011 03:32 PM
flare
Aug 12, 2010 07:04 AM
ramfan5.9
Apr 29, 2005 10:43 PM
