'02 T&C Power Sliding Door needs Clutch Motor?
Old Mar 7, 2007 | 03:11 PM
beatle78's Avatar
Default '02 T&C Power Sliding Door needs Clutch Motor?
Hi everyone,
The passenger power sliding door on my '02 T&C LXi opens fine, but when I try to electronically close it I here a click and the motor doesn't turn on.
If I pull the handle at the same time as the click and "help" the door a bit, the motor kicks in and the door shuts fine.
The dealer told me that I need a new clutch motor. Is there only 1 motor in the door?
Or does anyone know what the "clutch motor" is?
Here's a picture of a door from a 2001 caravan. Can someone identify the "clutch motor" on here for me?
Thanks,
beatle78
Old Mar 7, 2007 | 11:48 PM
ace's Avatar
ace
Default RE: '02 T&C Power Sliding Door needs Clutch Motor?
i could not see the whole pic but it looks like the dcx pic so i will tell ya its number 15 and you may need 16 as welll the cable we install them alot in pairs as i think dcx revamped it and you may need both of them.
Usually that is the problem the motor kinda fails for some reason or another.
Old Mar 8, 2007 | 04:39 AM
only one motor did they tell u anything about the code they pulled from the PSD module???
I hardly see motors messup more latches then anything.
dakrt360a
Oct 4, 2013 11:32 AM
Huslayer
Jan 28, 2013 10:14 AM
andy P
Feb 13, 2012 02:09 AM
stewartsoftware
Feb 27, 2011 03:54 PM
gregngina
Sep 28, 2006 12:01 PM
