02 TC abs ?
Old Jan 30, 2018 | 02:08 PM
streetmaster's Avatar
Originally Posted by REBEL59
I guess that I can no longer be of any help for you. You seem to be stuck on the thought that ABS is primary system, it is NOT. It is a "piggyback" system. if ABS fails it just stays as primary power hydraulic brakes. My estimation of things posted is you have a hydraulic system problem and ABS is secondary. Good luck to you in your quest to find and fix your concern!
Sorry for the confusion, but I think my intended ? got over looked, I completely understand that the abs isn't the primary system, otherwise we couldn't discontinue it by pulling the fuse, and still use the brakes. I pulled the abs fuse, only to have to car not turn over to start, but when I reinstall the fuse, the car starts, working on the abs/braking system isn't one of my strong points.
Old Feb 9, 2018 | 01:25 PM
bignev's Avatar
I agree with Rebel59 the ABS isn't related to your original fault, butto get it out of the way with the lamp illuminated have you tried pulling the relay out instead of the fuse?
I can't remember which way round it was with the fuse / relay, but I had a problem with the ABS being WAY too eager to activate, so barely had any brakes, so "turned it off" to be able to drive it
jimmy154
Dec 14, 2019 09:45 PM
bgborden
Mar 7, 2010 09:15 AM
driabyor
Dec 9, 2006 04:35 AM
mop queen
Dec 8, 2006 01:51 AM
Ironside
Feb 24, 2006 10:47 PM
