02 voyager stalling
hi guys. i hope you can help me with this stalling problem. my wife drives 02 voyager 2.4l. it stalls at least once a week. everytime i test drive it, it won't stall. she told me that it only stalls when she is stopping at the light, not during accelaration. when i test drove it, idle was ok. no rough idle. i did notice one time it chugg on me during accelaration when i lightly hit the gas. the only code thats stored was an egr leak. but i don't think thats anything to do with the stalling. i have change crank sensor, cam sensor, fuel filter, clean the throttle body.
any ideas what it could be?
also correct me if i'm wrong. i'm going towards changing the iacv. if it's a bad iacv, wouldn't it stalls on during accelaration and have a rough idle?
also, how do you check for a bad throttle position sensor?
whats even funny is that chrysler tech can't figure it out whats the problem when i brought it to the dealership. they're speculating what might be the problem and try to charge me for the things they will change, but might not fix the problem. how can a chrysler tech can't figure it out when all they work on are those cars?
Just so you know, they're trying to blow you out the door with a crazy stupid estimate so you will go away.....because you're being a pain in the @ss. You think there is a magical car machine that tells them exactly what happened and what to replace. It doesn't work that way.
Are you really that ignorant? Yes, someone should be able to tell you exactly what is wrong with your car when there are no codes and they can't duplicate your complaint that occurs once a week.
tksluke
17
Nov 7, 2012 09:00 AM
rickie_doo
Jul 8, 2011 03:45 AM
evansa uk
Sep 15, 2010 02:49 PM
dmbeale
Aug 7, 2009 09:13 PM
