03 T&C No start, steering wheel not locking
Old May 23, 2011 | 11:57 AM
Rando's Avatar
Default 03 T&C No start, steering wheel not locking
Hi all, new guy here so go easy. 2003 Town and Country 3.8. Wife drove to store and all fine. Comes home and shuts off.Later go out to start and nothing, key turns fine but will not start. I later notice the steering wheel does not seem to be locking either. I can still turn it with the key out. We are desperate and broke. Any suggestions would be great
Old May 24, 2011 | 08:29 AM
Rando's Avatar
Anyone please?
Old May 24, 2011 | 09:18 AM
are u missing spark or fuel when u try and star?
Old May 24, 2011 | 10:00 AM
Rando's Avatar
It doesnt crank over. It doesnt even click. I checked the starter relay with a known good one and it still does the same thing. The steering wheel will not lock but yet the key goes in and turns fine. I performed a test on the neutral switch and thats ok, it performs fine.
Could this be the lock cylinder even though the key turns fine? What about an ignition switch , can it cause the steering wheel not to lock?
Old May 24, 2011 | 05:11 PM
Rando's Avatar
I think Ill pull the lock cylinder tonight and just see if something is bound up if you will or sticking
Old May 24, 2011 | 09:57 PM
jump the starter relay see if the starter moves then
Old May 25, 2011 | 08:02 AM
Rando's Avatar
I pulled the lock cylinder, wiped it down etc. put it back in and it started but died right after, maybe ran 30 seconds, I tried pulling it again and now no start back to doing the same thing. a friends seems to think ignition switch ... does that sound right
Old May 25, 2011 | 11:25 AM
do u have a gray key ?
Old May 25, 2011 | 12:08 PM
Rando's Avatar
Only key I have is the orginal that came with the van.
Old May 25, 2011 | 11:32 PM
I will ask again is it gray or black ?
