04 town and country Ignition coil no 1 secondary circuit insufficient ionization
Old Mar 22, 2016 | 06:28 PM
dsgolmon's Avatar
Default 04 town and country Ignition coil no 1 secondary circuit insufficient ionization
I have tried to fix this vechicle myself. I have changed the spark plugs, wires and the igniton coil. It is still missing, jumping, idleing low, and just not running smooth. The four wires that go to the plug that goes into the ignition coil are all hot. I have foune out three are supposed to flash and not sure about the last one. One of the ones that is supposed to flash stays on constant. Is this because of the pcm or a bad wire connection somewhere?
Old Mar 23, 2016 | 03:29 PM
This a V6 petrol I take it. Per your change of coil 1 I take it there's 2 coils. Sounds like a coil issue but Idling low ! Does it power ok, if it does could be Lambda.
djs789
Sep 13, 2016 02:29 PM
brookblaze
Mar 2, 2011 03:35 PM
hambone
Jan 13, 2011 08:59 PM
04TroubleGenerator
Oct 13, 2010 07:54 PM
stonenrage
Jun 4, 2008 04:58 PM
