'05 T&C No Headlights???
Old Feb 15, 2010 | 09:10 AM
ACE'S FULL's Avatar
Default '05 T&C No Headlights???
Hello All
I have a '05 T&C that all of a sudden last night the headlights quit working. Now if you use the stalk on the the steering column and hold it the high beams work. I checked fuse panel with no luck. Anyone have thoughts on what could be wrong? Headlight switch?
Thanks in Advance.
Old Feb 15, 2010 | 09:40 AM
ACE'S FULL's Avatar
Did some other searching via Google and found this thread...
http://forum.chryslerminivan.net/sho...8979#post78979
Old Feb 15, 2010 | 01:45 PM
possible fcm or ipm fuse box or front controller
Old Feb 16, 2010 | 07:11 PM
ACE'S FULL's Avatar
So its not the switch?? Seems that was the common fix.
Old Feb 16, 2010 | 08:40 PM
I have never had to replace a headlight switch for headlights not coming on.
U can replace it if u want see if it works.
Old Feb 16, 2010 | 10:23 PM
First thing, check the bulbs. I once had both low beams blow at the same time on my old Concorde. Maybe it was a little voltage surge on old bulbs that did it but it can happen.
Old Feb 17, 2010 | 07:27 AM
ACE'S FULL's Avatar
The lights came on several times yesterday. Seems weird to me. If this is a common issue with this generation of van why hasnt there been something to address this issue? TSB or something like that?
Old Feb 17, 2010 | 12:13 PM
Check the circuit breaker.
Old Feb 17, 2010 | 02:48 PM
there is not one the front head lights along with the running and brake lights are computer controlled.
kahlil88
Nov 21, 2013 01:50 AM
Gliderflyer
Nov 11, 2013 05:53 PM
Brenda Elizondo
Apr 13, 2013 02:01 PM
dansdad90
Jul 13, 2011 03:54 PM
Comrade
Dec 6, 2010 07:42 AM
