06 GV - Leaf Spring Bushes
Old May 4, 2016 | 09:46 AM
sjbilton's Avatar
Default 06 GV - Leaf Spring Bushes
I got an MOT advisory that the leaf spring bushes were showing signs of wear, they are now occasionally knocking.
I can get the bushes from Car parts Jeep, Chrysler, Dodge, American - but popped down to the local tyre place this morning and they couldn't tell me how long/how much it would cost to change them. They started off at a couple of hours, and between them ended up at a day, and then maybe overnight.
Has anyone changed the bushes on their leaf springs? Arethey easy to do? Did any bolts snaps? Is it worth advance application of WD-40 etc? Any pitfalls or experience to share please?
Many thanks
Steve
Old May 5, 2016 | 06:01 AM
Usual way to get these bushes out unless you have a puller is destruction method by burning out rubber then cutting outer tube from inside. But a good heavy punch might do it as the spring housing is not complete due to how spring is made in a closed "C" at the ends. Replace with socket over outer bush and pull it through with screwed bar. Preparation is the key on fitting, smooth faces and lubrication.
SP10025
Oct 18, 2011 12:38 PM
Katfish
Apr 20, 2011 08:03 AM
Mike213735
Nov 3, 2009 04:35 PM
murdoch48
Jun 4, 2009 06:57 AM
comports
Mar 5, 2007 10:38 AM
