06 T&C Front End Noise
Old Oct 13, 2013 | 04:21 PM
swiederin's Avatar
Unhappy 06 T&C Front End Noise
I have a '06 Town & Country that is making a noise from the driver side front end. When you turn the wheel or go over bumps is sound like a popping noise.
I jacke dup the front left and turned the wheel and put my hand on the stabilizer bar link and i could feel it popping. I have once replace the sway bar links once before....I also put my hand on the stabilizer bar and could feel it popping as well.
Any ideas?
Old Oct 14, 2013 | 11:23 PM
MrSaratoga's Avatar
Any ideas?
Hello - I just got my first Town and Country...literally bougt it yesteday, so am still learning about Chryslers, but I can speak to the same issue I had on my old Pontiac Montana.
I think you are on the rigt track...check the ball joint and tie rod ends for play. I had same symptoms and turned out the tie rod ends were completely shot.
My five cents...hopefully more replies are posted but, definitely check those two items. Good luck!
Steve
Old Oct 16, 2013 | 01:45 PM
Stabilizer bar Rubbers is your problem. I've got same problem after changing control arms, links and said rubbers at beginning of year. These rubbers whether inferior material are not lasting long.
Old Oct 18, 2013 | 03:10 PM
ChryslerCares's Avatar
If the vehicle exhibits a muffled rattle sound which is heard during low speed
driving on road surfaces with minor fluctuations (such as a parking lot) and during turning maneuvers you may need to either replace front sway bar bushings at the frame and/or a couple Front Sway Eliminator Links (Part #04743669AA)
rtp
May 25, 2024 07:40 PM
burkj
Aug 20, 2014 03:26 PM
wagon22
Jul 18, 2007 09:30 PM
gaz440
Feb 21, 2007 02:37 PM
matune1
Jul 28, 2005 05:43 AM
