08 T & C Backup camera not working
Old Aug 25, 2013 | 01:03 PM
biga117's Avatar
Default 08 T & C Backup camera not working
I have a 2008 T & C and last week the screen started going black whenever I put the van in reverse. I checked the fuses I couldn't see anything blown but I don't really know which fuse goes to the camera or screen.
Old Mar 11, 2015 | 03:40 PM
biga117's Avatar
I have replaced the backup camera and M31 fuse keeps blowing causing the reverse light not to work. Any thought?
Old Mar 11, 2015 | 03:54 PM
royal100805's Avatar
Sounds like you may have a short in the circuitry. If you have access to a multimeter you should check continuity between the fuse and camera first and then if the connection at the camera has continuity with earth, the latter meaning you have a short to earth. This will draw too many amps causing the blown fuse. If so locate the part of the wire going to earth and repair or replace. Another way to confirm is to attach a longer seperate piece of wire from the fuse straight to the camera to eliminate the existing harness. If it now works without blowing the fuse you know the harness is the problem.
Good luck, Dan
str8hemi
Apr 5, 2010 12:54 PM
dealrocker
Oct 30, 2009 06:48 AM
data174
Apr 27, 2009 11:08 PM
atwong1
Apr 3, 2009 05:28 PM
chuckman
Nov 20, 2008 09:13 PM
