View Poll Results: Driveabilty
Buck and jerks
0%
Obd codes
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
1997 Chrysler town &country driveabilty
Old Nov 20, 2013 | 04:25 PM
Pooch69's Avatar
Angry 1997 Chrysler town &country driveabilty
Help!I have a 3.8l that intermittently bucks and jerks most times at high way speed.Codes cam/conk,some times ignition coil b primary/secondary circuit.Replaced all 3. Still same. after some thought I turn ignition between run & start the problem completely goes away.This problem started after a 30 mile ride to work and an 8 hr cold soak.I was a Chrysler Teck 14 yrs ago I wish I had a DRB.I feel like an old guy having to wear depends.HELP
Old Nov 21, 2013 | 01:24 AM
What are the pcode number? and replaced all 3 what? u only have one coil
Old Nov 23, 2013 | 12:20 PM
Pooch69's Avatar
Codes po352 and p1391 i replaced can,crank sensorsand coil pack.this problem is intermittent.i have also swapped asd relay,fuel pump relay,trans controller shutdown relay has happened 2times since i hold key between start and run the problem completly goes away.i have since wiggled all relays in the power distribution center the problem has not happened in 2 days.i keeping fingers crossed
Old Nov 23, 2013 | 11:52 PM
asd relay,fuel pump relay,trans controller shutdown relay they all have no bearing on this issue. Either a wire issue or pcm issue
Old Nov 26, 2013 | 05:05 PM
Pooch69's Avatar
Hay thanks for the help I am going to look in to the wire wiring. I hope it's not the PCM ,maybe poor ground,Green wire.
Ladyleprechan
Feb 21, 2014 08:30 PM
J Wikoff
May 15, 2012 03:44 PM
sportsfandallas
Feb 6, 2012 09:51 AM
sportsfandallas
Feb 3, 2012 01:28 PM
Stevo
Dec 2, 2011 11:38 PM
