1999 T & C intermitten wipers
Old Jul 20, 2009 | 03:17 PM
RSC's Avatar
RSC
Default 1999 T & C intermitten wipers
My delay wiper function doesn't work but the low and high speed do. My mechanic just replaced the entire switch assembly from the steering column and it didn't fix the problem. He put the old one back in. If I turn on the wipers and try to use the delayed function, the wipers start to move and then stop. Then when I turn them off, they make one wipe and return to the down position. Anyone have any ideas? RSC
Old Nov 18, 2010 | 08:43 PM
Virg///M3's Avatar
By any chance, did you find a solution for your problem? I have a '03 T&C & my wipers has only one speed (Fast) and then it won't stop at its home position. I would have to play with it until it stops low enough so that it does not block my view.
Old Nov 20, 2010 | 03:11 AM
dcm1971's Avatar
I believe there is a microswitch in the mechanics, and that can go faulty, I have the same issue (mormal and fast ok, intermittent can work or have a fit).
Old Nov 21, 2010 | 07:58 AM
RSC's Avatar
RSC
Default 1999 T&C intemittent wiper
By "Mechanics" do you mean the switch may be physically located on the outside of the vehical near the wiper motor? Rick
Old Nov 21, 2010 | 08:03 AM
RSC's Avatar
RSC
Excuse my mispelling of "Vehicle". Should have clicked "Check Spelling". RSC (Rick)
Old Dec 1, 2010 | 11:13 PM
Virg///M3's Avatar
My issue was fixed. My mechanic told me that the new wiper lever switch that was installed was not properly connected or something. Sorry, can't be any clear then this. I guess bottom line try a new switch.
Old Dec 2, 2010 | 02:36 AM
RSC's Avatar
RSC
When you refer to the lever switch, are you talking about the entire assembly at the steering column? Rick
Old Dec 2, 2010 | 11:34 AM
Virg///M3's Avatar
Yes Rick, the entire assembly.
Old Dec 2, 2010 | 12:58 PM
gonzo's Avatar
hi. this wiper problem sounds like a faulty relay.try removing and a spray of wd40.if this doesnt work then replace.good luck
Contact
Mar 1, 2013 07:56 AM
Revots12
Jun 27, 2011 09:48 PM
beast39
Mar 9, 2011 08:47 PM
deadchef
Mar 7, 2010 04:18 PM
2005TCVAN
Jul 24, 2008 09:08 AM
