1st post - 2002 power sliding door lock question
Old Sep 21, 2007 | 09:49 PM
pittstategorilla97's Avatar
Default 1st post - 2002 power sliding door lock question
Great forum! Just purchased a 2002 T&C EX with 62k miles. Having a couple of problems with the driver side power window and the driver side power sliding door lock.
I've done some searching and I think the power window issue can be attributed to the motor. I'm going to work on that tomorrow.
I have a question in regards to the power door lock on the driver side power sliding door. All other locks open and lock with the key fob or by manually pushing the lock button. The lock on the driver side power sliding door will only lock and unlock manually, but it does look like it moves just slightly when I push the lock button. Any sugesstions on what I should be looking to fix this issue?
Thanks in advance.
Old Sep 22, 2007 | 08:52 AM
Default RE: 1st post - 2002 power sliding door lock question
door lock accuator
Old Sep 22, 2007 | 11:45 AM
Do I need to check for loose wires or lube the actuator? Any steps or procedures would be greatly appreciated.
Thanks.
Old Sep 23, 2007 | 12:21 PM
if u ahve a test light or meter u can move the switch and see if u get the power and ground while u move it.
Old Sep 24, 2007 | 08:15 PM
I fixed the power door lock today onthe drivers side sliding door, it was in fact the actuator. I was able to buy the actuator from my local stealership for $113, ouch!! I could have gotten it for $85 on-line, but I was impatient and wanted to fix the door today. The entire latch assembly was $175, double ouch!
Old Sep 24, 2007 | 11:20 PM
welcome
Old Nov 11, 2008 | 03:13 PM
willsmith's Avatar
I had a similiar problem with the passanger sliding door on my 2006. Looked like the lock would try to electrical loce/unlock, but would not completely do the job. For some reason, the battery ran down. I put anotherbattery in temporary amd the lock started working ok. Pit orginal battery back in and still works. Is there something that could have reset by taking out battery?
dakrt360a
Oct 4, 2013 11:32 AM
neex
Aug 28, 2013 01:52 PM
Lassie
Feb 7, 2013 09:07 AM
Huslayer
Jan 28, 2013 10:14 AM
METERSF
Apr 6, 2011 05:01 PM
