2.8crd accessory drive tensioner replacement
Old Jun 25, 2016 | 08:12 AM
glensouk's Avatar
Default 2.8crd accessory drive tensioner replacement
I am trying to replace the accessory drive tensioner on a 2007 2.8CRD GV . I have removed the lower shields behind the front wheel and have removed the PAS belt and the serpentine belt and i have also removed the bolt fixing the tensioner to the engine . But now I cannot get the tensioner out from between the engine and the chassis rail . Does anyone have any advice on how this is done. thanks in advance.
Old Jun 28, 2016 | 05:23 PM
imtattoo80's Avatar
maybe will help if you disconnect engine mount and then try to rise or lower engine to get enough space. First secure engine with jack so it wont fall to the ground.I remember i did something like this with my first old voyager when replaced water pump.Disconnected one mount and pushed engine to get extra 5mm i really needed. May help and may not.
lovenhate300m
12
Mar 29, 2012 11:50 PM
donnyohs
Apr 28, 2009 04:19 PM
Iowacat
Aug 24, 2008 09:44 PM
jquinones
Feb 2, 2008 11:29 AM
eyruegas
Jun 20, 2007 07:43 PM
