2.8crd injector
Old Feb 15, 2013 | 12:45 PM
crow's Avatar
Default 2.8crd injector
hi all, does anyone know if there is another bosch injector that will fit a 2.8crd g/v 54 model, at the moment mine as bosch 0445110059 in, after doing some research these also are used in ldv's, cherokee's and some sprinters.but if you look at sprinter injectors they seem to use alot of different 1's some with a slightly different number some have 069 instead of 059, so do chrysler do the same, different injectors ,might seem a silly question only asking cause i need all 4 but for some reason chrysler injectors seem more expensive, not really cost effetive to pay silly money would be better scrapping it cheers
Old Feb 15, 2013 | 01:56 PM
Scotsman4th's Avatar
To me anything that is a bosch 0445110059 should be ok, but when I once went to remove injectors from an LDV Maxxus, the tool that removed them from my 2.5 CRD voyager didnt fit round them.
Have you had yours tested? I've heard theres places that will test them for around £25 each. If any's needing repairs they will take the £25 off the cost of the repair.
Old Feb 15, 2013 | 03:01 PM
crow's Avatar
cheers for the reply,not had them tested yet, it's done nearly 200,000 miles now still loads of life left in it yet did the rings and turbo about 20,000 mies ago, getting quite a bit of white/grey smoke when i first start in the morning and fuel comsumption is poor, going to do a leak back test on them over the weekend to confirm, the problem i have is i will be using it for work so in 2 minds if to get them done or not or just to buy a van
Old Feb 16, 2013 | 02:38 AM
tfb's Avatar
tfb
According to Bosch ESI-tronic here's the part numbers manufacturers use for the same injector.
royal100805
Dec 24, 2014 01:36 PM
Scotsman4th
22
Jan 14, 2012 04:55 PM
goblue2010
Jun 29, 2010 02:05 PM
Interceptor9C1
Feb 17, 2010 11:58 PM
Oldbazzer
Aug 17, 2009 10:39 PM
