2000 Chrysler Voyager Transmission Problem
Old Jan 2, 2008 | 02:56 PM
burrell9's Avatar
Default 2000 Chrysler Voyager Transmission Problem
Ok in the morning this just started happening car starts up fine goes into reverse but when you put it in drive it's like it's in Neutral. has no drive and just rev's I guess you would say this is Limp mode. I let it warm up for a while and then it drives fine.. until the next when it does the same thing it does not shift hard or anything.. Have not checked fluid, just wondering if this is a winter thing?.. or is My transmission about to go. Bought the car in July and it has never showed no problem during shifting but is weak on the big hills. I have had a Solenoid Switch Pack go bad on a 02 Intrepid butit didnt do this and the speedometer works.. any help would be great the check engine light does not come on at all.
Old Jan 2, 2008 | 06:47 PM
moe's Avatar
moe
Default RE: 2000 Chrysler Voyager Transmission Problem
i would check your fluid level first,if it ok then i would have to say your seals are hardening,common in cold and hot weather.sounds like it time for overhaul.or let trans warm up.before dropping into gear.moe
Old Jun 17, 2013 | 03:16 PM
gearhead1's Avatar
Default 2000 chrysler grand voyager
I have a 2000 Chrysler grand voyager and it went into limp mode.. I changed the input and output sensors on the trans. it changed absolutely nothing now I don't know what else to try anyone have any suggestions?????????
Old Jun 17, 2013 | 03:27 PM
gearhead1's Avatar
the speedometer doesn't work either????? im just about at my witts end with this vehicle can anyone help??
Old Jun 18, 2013 | 12:38 AM
get the codes from the transmission computer should have been the first thing U did
jminter
Jul 3, 2019 10:14 AM
Voyager_2000
22
Aug 28, 2015 06:07 PM
SWTomlinson
Jul 16, 2011 06:55 AM
lexusnrg
Jan 3, 2011 02:23 PM
chris015
Nov 10, 2009 09:56 PM
