2000 T&C 3.8 po107 po108
Old Jul 22, 2011 | 07:50 PM
Confused Chick's Avatar
Unhappy 2000 T&C 3.8 po107 po108
My 2000 T&C 3.8 started running horribly. Irractic idle, intermittant dying at idle. On the expressway it would run fine for a few minutes before it would start stalling out, it even died a few times.
The original code was po107 - MAP pressure circuit low input
Replaced the MAP sensor - now recieving the same po107 code but now also receiving po108- which says MAP pressure circuit high input
As far as expressway driving, it has done fine although I haven't driven it long enough, IMO,to know for sure those issues are gone.
But at an idle -the tach is still irractic and it sometimes dies out. It may take me 3 or 4 cranks to get it restarted.
Someone told me to continue to drive it, as it may take a few drive cycles in order for the computer to recognize the new sensor. Is this a load of crap or should I give it a go?
Are there any other issues that could cause this trouble codes?
It's 115 degrees outside and I am tired of sitting out in this heat dealing with this. Not to mention breaking down on the highway with two young kids is scary.
Any advice or tips would be so so so much appreciated! Thanks
Old Jul 22, 2011 | 09:09 PM
check the wires from the map sensor to the PCM
james quinn
Nov 22, 2013 06:35 AM
DRFUZZ
Jan 6, 2010 10:19 AM
d3aglewhor3
May 5, 2009 12:58 AM
chryslervan
Mar 21, 2009 10:07 PM
chryslervan
Mar 16, 2009 07:02 PM
