2000 town & country 3.3 lt
Old Nov 17, 2011 | 04:55 PM
warmar70's Avatar
Default 2000 town & country 3.3 lt
engine light on, transmission slips. checked with a hand held digital diagnostic tool. codes are po7030 gear 4 incorrect ratio and po7032 gear 2 incorrect ratio. also p1781, p1782, p1784 and po700. what do i do now?
Old Nov 17, 2011 | 09:00 PM
TNtech's Avatar
Sounds like you lost fluid pressure in the trans. Was there a code named "Loss Of Prime" Does it makes a whizzing noise while it slips?
Old Nov 18, 2011 | 10:56 AM
warmar70's Avatar
no code for loss of prime, it does make a whizzzing sound when it slips.
Old Nov 18, 2011 | 11:03 AM
warmar70's Avatar
what needs to be done if loss of prime?
Old Nov 21, 2011 | 06:05 PM
warmar70's Avatar
Default 2000 town & country 3.3 L.
code p0734 gear 4 incorrect ratio, p0732 gear 2 incorrect ratio, p1781 pressure switch circuit 0D, p1782 pressure switch circuit 2-4, p1784 pressure switch circuit LR, p0700 transmission control system MIL request.
what do i need to do with this problem ?
Old Nov 21, 2011 | 07:11 PM
Raptor 07's Avatar
If you don't get an answer here head over to DodgeForum.com or The Chrysler Minivan Fan Club . There are several tranny techs on the forums.
Old Nov 22, 2011 | 12:19 PM
TNtech's Avatar
The whizzing is usually indicative of torque converter malfunction from loss of fluid pressure. It means a rebuild....probably. First thing I would (that you can do yourself) is drop the pan and see if there is any metal in there. Then you will have no doubt.
Old Aug 17, 2013 | 04:28 PM
warmar70's Avatar
where do I check manually the oil pressure on a 3.3 engine in a 2000 Chrysler town & country?
Old Aug 18, 2013 | 04:58 PM
Leedsman's Avatar
One assumes you've checked for loss of ATF fluid, i.e. correct on the dipstick under conditions as outlined?
Leedsman.
Eirelin
May 18, 2012 07:09 AM
2000 T&C
May 1, 2012 12:49 PM
Baronesa
Aug 22, 2011 11:09 PM
bosslady38
Jul 6, 2010 08:39 PM
DRFUZZ
Jan 6, 2010 10:19 AM
