2001 grand voyager severe splutter problem pls help:-(
Old Nov 1, 2015 | 02:55 AM
Soniabulpin's Avatar
Default 2001 grand voyager severe splutter problem pls help:-(
I have a 2001 grand voyager 3.3 that usually idles great and revs fine. Also when you drive it in reverse it runs fine but when you put it in drive it with either stall out or sputter really bad. If I barely give it gas it will start to cruise and the gears in the transmission shift smooth and I can get it up 35-40mph but if I step on the gas good it will start to sputter and then die out. It has the engine light on so I ran the code. It has several codes pointing at the tps, low 5 volt voltage and pcm. Took it to several garages but they are unsure. We took throttle he's off and cleaned the idle air valve and the car worked fine for about 50 miles but now back to square one..
Sometimes it will die right away as soon as you put it into gear.
Any ideas or suggestions would be great fully received
Old Nov 1, 2015 | 03:07 AM
Vmaxxer's Avatar
I think it will help the Chrysler guru's helping you if you post the error codes here
Old Nov 1, 2015 | 05:36 AM
The low 5 volt one is the interesting one pointing to a sensor. Then after removing idle valve and refitting it lasted 50 miles possibly pointz to a wire you disturbed that has a resistance in it. I take it you have checked all wires including ones near exhaust pipework.
Old Nov 1, 2015 | 01:27 PM
😀 yay we fixed it... After reading your comment about a wire fault my husband searched the whole engine bay and found a red wore that had melted on a pipe just above the gearbox.. Who would of beleaved that a wire would of caused so many problems!!
3 garages the car has been too and lots of money and it took my husband to fix it..:-)
Old Nov 1, 2015 | 01:28 PM
Thank you
Old Nov 1, 2015 | 02:05 PM
Go to the top of the class Goggsy
Old Nov 1, 2015 | 02:50 PM
Just now thinking of possibly the same fault on here not long ago where culprit was a wire, red possibly, between auto box and a module. Not sure if it was fried.
Anyway we are all glad you found the fault before pulling your hair out.
Old Nov 1, 2015 | 04:00 PM
tfb's Avatar
tfb
nice one
shazmataz
Nov 21, 2012 07:51 AM
Alguien
Jun 25, 2011 08:00 AM
coolsat
Nov 28, 2010 08:49 PM
04Pacifica393
Jul 13, 2009 09:29 AM
mykej27
Mar 12, 2007 09:22 PM
