2001 T&C 3.8 All Wheel Ltd...random stall
Old Dec 15, 2010 | 08:49 AM
b_ron007's Avatar
Question 2001 T&C 3.8 All Wheel Ltd...random stall
185,000 miles on it, bought over 3 years ago. Within this year, the van has started to pick up a random stall. Its starting to do it more now. I've removed the intake duct to the throttle body, and have blasted clean the throttle body and the IAC valve intake area just above the throttle body opening with carb cleaner....at least thats what I believe that crescent looking hole is.
Theres no codes. This morning, my wife started the van to warm it up. When she went out there, the van was not running anymore, but everything else was on, soo it must have stalled. She started it again and went back in, and the same thing happened. No codes! She started it for the third time, and no problem......van warmed right up!
My question is....does this seem like a fuel filter issue?
thanks again,
byran
Old Dec 15, 2010 | 08:56 AM
b_ron007's Avatar
I have also checked for EGR valve for movement as its suppose to, and thats fuctioning properly.
Old Dec 15, 2010 | 09:10 AM
ettienne's Avatar
Remove the idle control valve from the throttle body and clean the metal part that sticks into the throttle body. I used a brass wire brush to clean all the gunk off, also clean the throttle body area where the idle control valve fits in.
When last was the air filter and spark plugs and wires replaced? These may not be the main cause of the problem but could contribute to the problem.
Old Dec 15, 2010 | 09:18 AM
b_ron007's Avatar
I've replaced the plugs less then 15,000 miles ago. Wires i didn not replace. Air filter I just replaced when I did the oil change less then a 500 miles ago.
Whatcha think bout the fuel filter tho? I will change it, but too much gas in the tank right now! Are these symtoms a fuel filter will cause?
Old Dec 15, 2010 | 09:21 AM
b_ron007's Avatar
i've used almost half of a can carb cleaner spraying it down both openings, and I'm talking about a big can. you don't think that would of got the job done?
Old Dec 15, 2010 | 09:39 AM
ettienne's Avatar
You will be surprised how much gunk is stuck to that metal part and how tough it is to get off.
Old Dec 15, 2010 | 09:45 AM
ettienne's Avatar
A clogged fuel filter could also cause problems, replace it as well.
You have new spark plugs and air filter, that's good. Spark plug wires should also be replaced every 100k.
Old Dec 15, 2010 | 11:01 AM
b_ron007's Avatar
aight.....just came from a drive. I have to rule out fuel filter. I have never had driveablity issues, and i can floor it and it just goes!
I got beer to help me focus. Gonna clean this IAC valve.
Old Dec 21, 2010 | 04:40 PM
b_ron007's Avatar
is there anyone here that can help?
I still get a random stall! Cleaning the IAC valve didn't fix the problem. The IAC valve works as it should.
Old Dec 21, 2010 | 04:44 PM
b_ron007's Avatar
the only one posting is the one who has a similar problem. anyone else?
chryslerboy
Aug 22, 2019 03:27 PM
hammer13
Cirrus & Breeze
16
Aug 27, 2013 10:28 AM
zoom zoom
Apr 17, 2013 09:46 AM
b_ron007
Dec 15, 2010 10:05 AM
tc_2004
Oct 7, 2009 10:56 PM
