2001 T&C 3.8L Idle Problem
Old Nov 2, 2007 | 05:39 PM
vince01's Avatar
Default 2001 T&C 3.8L Idle Problem
Any ideas will help here.
My wife's '01 T&C idles high. She said it was idling at 2k and remains there until she puts it in gear then it drops to 1.5k. Also, when driving at moderate speeds when she takes her foot off the accelerator the van maintanes its speed. Would this be caused by the throttle position sensor?
Old Nov 2, 2007 | 07:22 PM
carbuff2's Avatar
Default RE: 2001 T&C 3.8L Idle Problem
Try cleaning the throttle body and butterfly. Use ONLY an intake cleaner that is safe on plastics.
In fact, don't spray the cleaner directly in, just soak a lint-free rag and wipe the outer and inner edges of the butterfly and the mating surfaces.
Edit: You may want to look for an air leak as well...a cracked inlet hose from the air cleaner for example.
Old Nov 3, 2007 | 10:09 AM
vince01's Avatar
I will check those things today. Autozone checked the codes for my wife and it came up with "idle speed not achieved."
Old Nov 3, 2007 | 09:52 PM
master tech's Avatar
Remove the throttle body and clean, also remove the ais motor and clean as well. If that don't help maybe you have a vacuum leak.
chryslerboy
Aug 22, 2019 03:27 PM
70 roadrunner
Dec 3, 2014 07:48 AM
bchalker
May 6, 2011 06:25 AM
macfarlane300
Feb 2, 2009 09:00 AM
Newf
Jun 22, 2007 11:22 PM
