2001 Uk Grand Voyager - Reverse lights stopped working
Old Sep 12, 2010 | 06:20 AM
xjr41's Avatar
Default 2001 Uk Grand Voyager - Reverse lights stopped working
Hi,
Can anyone help?
I have a 2001 manual Grand Voyager and both the reverse lights have just stopped working.
Is there a fuse somewhere for these, or is there a gearbox switch that tells the lights when the cars in reverse?
Thanks,
Steve.
Old Sep 15, 2010 | 02:41 PM
Merlin's Avatar
Hi
There is a recall for reverse light switch might be an idea to get this check out.
Old Sep 17, 2010 | 05:57 PM
xjr41's Avatar
Thanks for the reply. How do I go about checking this recall? Do I need to just contact my local dealer with the VIN number? Does the recall have a specific number I can quote to them?
Thanks,
Steve.
Old Sep 19, 2010 | 03:10 PM
Merlin's Avatar
No just give them your vin and ask them to run a VIP sheet as for may also have other recall outstanding.
Old Jul 19, 2014 | 08:03 AM
Robert McGregor's Avatar
Hi,
New Chrysler owner but old second hand Chrysler bought... I have the same issue in that the reversing lights have stopped working. This info is 6 years old, is it still valid or am I just going to have to speak to a mechanic and get it sorted...?
Cheers,
Rob.
Old Jul 19, 2014 | 08:04 AM
Should have said, I have an 03 plate 2.5 Diesel Manual Grand Voyager... if that makes any difference.
Ta,
Rob.
Old Jul 19, 2014 | 02:29 PM
Go back to 11-21-2013 No reverse lights. I've got same problem still to sort out. It seems its the BCM that controls the rear backup lights, but the signal for it must come from the Gearbox. Auto-boxes probably get signal from gear its in on dash.
I was told by my MOT Garage that I needed a new gearbox switch and asked if I wanted it ordered. Would have got it sorted by now if I had.
Wire for Backup lights in boot is White/Light Green.
2003 Voyager Ltd, 2.5CRD.
Old Jul 20, 2014 | 12:06 PM
Brilliant - I have located a tame ex-Chrysler mechanic who I have to contact and see how helpful he is so will ask about this and if it might be any other issue and what about the costs of potential problems and will post back if I find anything new.
Cheers goggs.
Rob.
Old Jul 21, 2014 | 04:04 PM
Raptor 07's Avatar
On a US spec van at least, signal comes out of the Transmission Range Sensor in the transmission (4 speed **) to the Front Control Module (FCM). From there it goes out on the PCI data bus to the BCM then out to the lights.
** If you have a 3 speed tranny it uses an old tried and true park/neutral switch external on the tranny.
Old Jul 22, 2014 | 02:04 PM
Cheers Raptor, it's not I'm afraid... It's a UK model 5 speed manual transmission.
(I should update my signature)...
I see that others have replaced the actual switch in the gearstick housing and the BCM unit so i'll start cheap and try the switch, though I still should call Chrysler if that was good information about a recall for this exact fault.
Cheers all,
Rob.
