2002 CRD alarm fault
Old Sep 14, 2011 | 01:57 PM
robtheplumb's Avatar
Default 2002 CRD alarm fault
Hi all, I have a 2002 CRD 2.5 diesel that has developed a fault on the alarm, it just keeps on going!!!!!
The car will not start, the central locking does not work, no lights come on, nothing works apart from the alarm!!!!! I have disconnected the battery as this is the only way to shut the thing up. Have tried unlocking doors, leaving the key in the run position in the ignition before reconnecting the battery, tried fuses, relays, in fact most things apart from ripping the whole lot out!!!
Anyone any idea??
Old Sep 15, 2011 | 08:43 AM
Anyone???
Old Sep 15, 2011 | 10:27 AM
voyager_dan's Avatar
there is a fuse in the engine fuse box for the pcm remove this turn ignition on then off then replace fuse and switch ignition on again the dials will all go round as it resets itself
give this a try it may work
dan
Old Sep 15, 2011 | 02:23 PM
Will do, thanks Dan
Old Sep 15, 2011 | 05:18 PM
Default No luck
Tried your thought Dan, still nothing
Anyone else got any clues?
Old Sep 29, 2011 | 02:12 PM
Bump...
Old Sep 29, 2011 | 03:13 PM
where are you ?
voyager3000
Jul 18, 2012 02:11 PM
Jimbo1
Feb 24, 2012 05:16 PM
star
Jun 8, 2011 07:31 PM
stewartsoftware
Apr 17, 2011 03:22 PM
Ian
Aug 9, 2009 05:28 AM
