2002 T&C Van
Old Nov 12, 2014 | 04:32 PM
Keibler98's Avatar
Default 2002 T&C Van
Can anyone help with a heating issue? Sometimes it will blow hot and sometimes cold.
Old Nov 12, 2014 | 06:01 PM
roadman's Avatar
sounds like my wife.....as mentioned in the introduction section ...check for water under the front passenger side floor mat...you might have a heater coil problem
Old Nov 13, 2014 | 09:15 AM
Keibler98's Avatar
Roadman,
There is no water there. Kinda of thinking the blend door from other post i've read but still not sure
Old Nov 13, 2014 | 10:30 AM
low coolant in the radiator is one of the main causes
Old Nov 13, 2014 | 11:14 AM
Keibler98's Avatar
Chrysler Tech,
The coolant is full. Anything else you can think of?
Old Nov 13, 2014 | 02:09 PM
Header tank full doesn't mean there's coolant in the heater. It needs bled.
Old Nov 13, 2014 | 08:58 PM
full in teh radiator not the over flow tank?
Old Nov 14, 2014 | 07:13 AM
- we - the group might be able to help
- but diagnostically it would depend on what information we are given
- as yet you have given none, example, when does it it blow hot / cold ?
- example always cold unless heater turned to full, then its always hot
- means a lot, and points to a specific fixable probability to anyone on this forum
- so give us some info on when and at what settings it is variously hot / cold !
Old Nov 14, 2014 | 02:16 PM
Keibler98's Avatar
The hot and cold blows randomly regardless of the fan speed. I have it set on high heat.
Keibler98
Nov 12, 2014 05:58 PM
2009DodgeGrandCaravanSXT
Jul 1, 2013 09:57 PM
ekhealy
May 23, 2011 10:47 PM
lwrdrhvn
Feb 12, 2011 09:48 PM
Chrysler_Lover
Dec 12, 2010 05:12 PM
