2002 Town and Country Fan problem
Old Mar 16, 2009 | 07:08 AM
300winchester's Avatar
Default 2002 Town and Country Fan problem
I have a 2002 Town and Country van, the front fan only works on high, any ideas, ? Thanks in advance
Old Mar 16, 2009 | 01:09 PM
Rick99's Avatar
If manual system-- blower resistor
If ATC-- blower control module
There's lots of info-- try a quick search.
Old Mar 22, 2009 | 11:30 AM
GroceryGetter's Avatar
Most def. blower resistor..I just replaced mine and everything works fine..Disconnect neg.(black) terminal on battery, empty glovebox push sides of glovebox in and glovebox swings down. The resistor is right in front of you..Disconnect the 2 harnesswires, then 2 screws and slide new one in, plug in and done. I got mine at O'Reilly Auto Parts for $14.00..Good Luck!!
Old Mar 23, 2009 | 06:45 AM
Default thanks
Thats what I needed, a good definition on where to fix, thanks much
MGM
Old Mar 23, 2009 | 01:29 PM
MGM
Anytime, Now If I could just figure out to get rid of that annoying humming noise when the fan is on high I would be !!
Philip
Old Mar 23, 2009 | 02:17 PM
drop the fan and get the trash that is inside there.
Old Mar 24, 2009 | 12:37 PM
Mr. Keller,
Can you please tell me how to get access to the fan and clean the trash out...I tried taking the bottom of the blower motor housing off, but because of access restraints I stopped. Can you point in a different direction or some instructions for a simpler task..Thank you for your help!!
Old Mar 25, 2009 | 12:03 AM
what year fan do u have?
Old Mar 25, 2009 | 04:01 PM
Its a 2001 Chrysler Town & Country LX
Old Mar 25, 2009 | 10:38 PM
never mind live with the noise U haft to take out the dash and hvac housing to remove the blower.
