2003 T&C rear A/C
Old Mar 20, 2013 | 11:47 AM
LonAllen's Avatar
Default 2003 T&C rear A/C
I recently noticed that when the rear A/C is blowing I can smell PAG OIL from the freon really strong. A few weeks have gone by and I have not ran the rear A/C and the front A/C still blows cold. If the rear A/C is turned on the smell of the oil is really present.
I have read a few posts that the evaporator extension tubes can go bad or the seals on these tubes go bad. Am I able to check for a leak without having to remove the evaporator housing from the vehicle and/or keep from disconnecting the the box from the hoses under the van? Because the smell is so strong I have a suspicion the problem is the evaporator, but I'd like to know if it is the evap or the tubes/seals.
Any thoughts or suggestions?
Thanks,
Lon - '03 T&C Limited 180K miles
Old Mar 20, 2013 | 12:10 PM
Djinn-n-Tonic's Avatar
Unfortunately ...No.
Both the tubes and evaporator are contained in a "Shroud" of the rear heater case. you may be able to detect a leak, but differentiating the two components is impossible without actually seeing them. the box itself is really not difficult to remove, (I usually leave the heater core attatched to the hoses and leave it in the car when I pull the box out) so the only issue is the freon recharge.
Old Mar 21, 2013 | 06:09 AM
LonAllen's Avatar
Djinn,
Thanks for the info. I guess I will have to pull it apart and see what's in there. I don't want to order parts I don't need. Its inconvenient to have to return unused parts (especially if you get them On-line).
I had to replace the rear evap on my 1994 T&C back in the day. I figure it can't be that much different.
Any statistics on what fails the most (the extension tubes or the evap)?
Old Mar 21, 2013 | 05:10 PM
Typically , depending on where you live, the road salt in the winter splashes up and wreaks havoc on the extension tubes and under car lines. I live in the Northeast salt belt, and they very rarely escape the Corrosion.
Ooops.....Check with your local dealer, I seem to remember a modified "KIT" for T+C, Caravan and Voyager......even if its just a part number, it can be matched up after market. Its an evaporator , extension tubes , orrings and weather seals . I was using them on primarily 06 and 07, but there isnt any difference to "03".
Old Mar 22, 2013 | 07:59 AM
LonAllen's Avatar
Djinn,
Do you recommend aftermarket parts for the Evap and extension tubes? I have seen the Evap is really cheap compared to Mopar. I usually get my parts from an on-line Mopar shop here in Tampa and the evap is about $100 off what the dealership wants. I did call one dealership and the guy told me the rear evap is no longer carried by them and I would have to order it from Vintage Parts which apparently took all remaining stock.
Old Mar 22, 2013 | 06:09 PM
Originally Posted by LonAllen
Djinn,
I cant seem to get To my "Cloud" at the moment, but if you Google
TSB 24-005-10
There will be a list of part numbers.... By all means , if you can get MOPAR PARTS, then that would be best. You will have to discuss this with your online supplier, and ENSURE the parts interchange, but at least it will give you a guide.
Meniil
Nov 30, 2014 10:00 AM
scotto58
Oct 28, 2014 04:51 PM
schico
May 11, 2009 02:24 PM
dirtfrmr
Jan 9, 2008 02:53 PM
medencev
Dec 14, 2006 08:07 AM
