2003 town and country not getting power to a/c compressor
Old May 13, 2018 | 11:06 AM
doitmyself's Avatar
Default 2003 town and country not getting power to a/c compressor
2003 t&c 3.8l with rear a/c
I just pulled a vacuum on the system, it took 3-12 oz cans of freon.
the compressor was not coming on, checked the relay and fuse were good
pulled the wire plug at the compressor and can not get power at the plug, while turning on the a/c on and off from the control panel.(blue wire is hot wire)
When turning the a/c on;/off when turned on the engine idle would increase (to me this means the control is working?)
when checking the relay contacts at the fuse box under the hood, I could not find a ground at any pin?? this does not seem correct......
would like to find wiring diagram that shows the circuit from control panel ,to fuse box (relay)and fuse, to compressor.....
would like to know what the contacts at the relay should read.
thanks
Old May 14, 2018 | 03:53 PM
buy a service manual it will have a wire diagram for you
Pebbleskn
Dec 20, 2024 12:58 PM
KEng
Apr 25, 2018 06:51 AM
doitmyself
Apr 22, 2018 01:34 PM
Joe.G
Apr 7, 2016 07:49 AM
CML
Jun 20, 2010 04:30 AM
