2003 town and country limited fog lights will not work
Old Apr 22, 2018 | 07:25 AM
doitmyself's Avatar
Default 2003 town and country limited fog lights will not work
03 town and country fog light do not come on, when the headlight switch is pull outward., I tried to turn on the fog lights with the headlight switch in all possible positions.,.the bulbs have been checked and are good.
the underhood fuse box fuse was blown replaced ,but still no foglights...also checked the relay for foglights (underhood),switched with the horn which is the same relay,horn works, but no lights...
not sure what to check next? can not seem to find a good wiring diagram. thanks for any help you can offer
Old Apr 22, 2018 | 07:50 AM
REBEL59's Avatar
Sounds like time to start checking for corroded/broken wires to the lights with a test light starting at the bulb connectors. There are so many places that could have a broken wire, that no schematic or advice could pinpoint where the fault may lay.
Old Apr 22, 2018 | 08:05 AM
doitmyself's Avatar
looking for a wiring diagram,so i can track it down, also so i can test the headlight switch to see if is sending the power to the fog lights
Old Apr 22, 2018 | 09:12 AM
BiliTheAxe's Avatar
Have you tried pulling out on the switch?
Some Mopars of that time period, you pulled out on the switch when the headlights were on to turn on the fog lights.
This has the wiring diagrams.
Please save it to save on the bandwidth.
https://app.box.com/s/167uw6pvkb4tda4mfzkxsmep274xlas7
Old Apr 22, 2018 | 01:34 PM
doitmyself's Avatar
Default yes ,I have pulled out on the switch
yep, tried that, but nothing
ikappa
May 23, 2022 04:44 PM
KJT
Feb 23, 2018 10:16 AM
tlray
Nov 11, 2017 11:56 PM
djufo
Mar 13, 2016 01:14 AM
cuda2000
16
Jan 14, 2014 03:42 AM
